Third Party Lenses
Tamron issues notice about Canon EOS R and EOS RP compatibility
From Tamron:
We would like to announce that we have clarified compatibility of following Tamron Di & Di II lenses on Canon EOS R and EOS RP with Canon “Mount Adapter EF-EOS R”.
Planned to be released (F/W release dates will be announced once they are decided.)
  • SP 15-30mm F/2.8 Di VC USD (Model A012) for Canon (*)
  • SP 70-200mm F/2.8 Di VC USD (Model A009) for Canon (*)
  • SP 70-300mm F/4-5.6 Di VC USD (Model A005) for Canon (*)
  • SP 70-300mm F/4-5.6 Di VC USD (Model A030) for Canon (*)
  • SP 90mm F/2.8 Di VC USD MACRO (Model F004) for Canon (*)
Compatible as they are
  • SP 24-70mm F/2.8 Di VC USD (Model A007) for Canon (*)
F/W readily available (Updating to the latest version confirms compatibility.)
  • 10-24mm F/3.5-4.5 Di II VC HLD (Model B023) for Canon
  • SP 15-30mm F/2.8 Di VC USD G2 (Model A041) for Canon
  • 17-35mm F/2.8-4 Di OSD (Model A037) for Canon
  • 18-400mm F/3.5-6.3 Di II VC HLD (Model B028) for Canon
  • SP 24-70mm F/2.8 Di VC USD G2 (Model A032) for Canon
  • SP 35mm F/1.8 Di VC USD (Model F012) for Canon
  • SP 45mm F/1.8 Di VC USD (Model F013) for Canon
  • SP 70-200mm F/2.8 Di VC USD G2 (Model A025) for Canon
  • 70-210mm F/4 Di VC USD (Model A034) for Canon
  • SP 85mm F/1.8 Di VC USD (Model F016) for Canon
  • SP 90mm F/2.8 Di MACRO 1:1 VC USD (Model F017) for Canon
  • 100-400mm F/4.5-6.3 Di VC USD (Model A035) for Canon
  • SP 150-600mm F/5-6.3 Di VC USD G2 (Model A022) for Canon
  • SP 150-600mm F/5-6.3 Di VC USD (Model A011) for Canon(*)
Operational only in MF (No plan for new F/W.)
SP AF 28-75mm F/2.8 XR DiLD Aspherical [IF] MACRO(Model A09) for Canon(*)
(*) Not supported in TAP-in Console.
[Note]
a. All Canon-mount models released after in May, 2019 are compatible with EOS R and EOS RP.
b. F/W updates can be performed using Tamrons TAP-in Console (sold seperately) or by visiting your local Tamron Service Center.
Antono Refa
Mar 26, 2014
929
174
In other news: All Canon manufactured RF lenses will be 100% compatible with all R series cameras... right out of the box. EF with adapter also.
Then again...
1. Some of those lenses are cheaper than their Canon equivalent, e.g. the 100-400mm zoom. That saving cost something.
2. Canon doesn't have equivalent for some of those lenses, e.g. an 18-400mm f/3.5-6.3 w/ IS crop lens, a FF 24-70mm f/2.8 w/ IS, fast normal lens w/ IS, a FF 85mm f/1.8 w/ IS, or the SP 150-600mm F/5-6.3 Di VC USD.
Reactions: CanonFanBoy
Avenger 2.0
Jul 30, 2017
48
33
The adapter likely has firmware with modificaties for each canon ef lens to make them work. Tamron has to reverse engineer the compatibility in their lens firmware.
Sporgon
Canon don't make the 45/1.8 VC. Mine is simply the finest all round lens I've ever had - it is sharp yet retains the softest of bokeh, a modern lens masterpiece. It really does deserve the title "Art" unlike the resolution monsters from Sigma that carry that title. And it looks like WEX who are the largest camera gear seller in the U.K. don't even list it anymore !! Which is brilliant because the less people that know about it now that I have mine the better ;)
CanonFanBoy
Really O.K. Boomer
Jan 28, 2015
4,702
2,622
Irving, Texas
I once had Tamron's 15-30 and it was also stellar.
May 14, 2019
3
Chemnitz
Does anyone maybe get some further informations about when the Firmware-Updates for the 70-300 and the 90mm Macro are avaiable?
Would realy need them in the next few months^^
