Another M5/6 set of questions: confusion about Combination IS
Jul 12, 2013
252
86
Pardon my confusion...
I read this [from--https://www.usa.canon.com/internet/portal/us/home/explore/eos-m-series/eos-m6 ]:
"^ Maximum image stabilization is achieved when using either the EF-M 18–150mm f/3.5–6.3 IS STM or the EF-M 15–45mm f/3.5–6.3 IS STM."
The quoted material is a footnote from here:
"The EOS M6 camera’s 5-axis Digital Image Stabilization^ helps minimize blur due to camera shake in nearly every direction such as up and down and side to side. When used with a compatible lens, it can also use Combination IS for additional shake reduction."
(1) What, exactly, do the terms Combination IS and 5-axis Digital Image Stabilization refer to, and are they video-only features?
(2) Is the Combination IS feature only accessible when using the 18-150mm and 15-45mm M lenses?
(3) Is the 'additional shake reduction' associated with Combination IS a video-only feature?
(4) Do the 'old' M lenses (10-22; 22mm; 18-55mm) derive any benefit (still images and/or video) from Canon's 5-axis Digital Image Stabilization?
I then read this [https://www.dpreview.com/forums/post/58632988]...which links to a late-2016 firmware update for the 15-45 lens to enable 'Support for Combination IS when the lens is mounted to the EOS M5, which coordinates optical IS and in-camera digital IS for improved stabilization in movies.'
(5) So, perhaps asking the same questions differently, are all of the in-camera digital IS effects for video?
Thanks for reading.
neuroanatomist
24,639
2,153
AFAIK, the sensor-based IS only applies during movie capture (because that is cropped, and the cropping allows digital IS). So, with stills using most lenses you get only 2-axis stabilization (pitch and yaw), although with the EF-M 28mm Macro you get 4 axes (pitch, yaw, X and Y) becuase that lens has Hybrid IS.
HaroldC3
Jul 6, 2014
114
31
Video only feature that (I believe) uses the sensor for a faux image stabilization since when shooting video it doesn't use the whole video. This works in conjunction with the lens IS.
Yes.
Yes.
No. It's only available for the 2 lenses mentioned above.
Yes, it's completely for video only.
Thanks for reading.
