Canon Firmware
Firmware: Canon RF 70-200mm f/2.8L IS USM
Canon has released their promised firmware update for the Canon RF 70-200mm f/2.8L IS USM to fix an issue at minimum focusing distance.
Firmware Version 1.0.6 incorporates the following fix:
  • Fixed a phenomenon when performing AF shooting to capture a subject at close-range with the focus distance approximately set to the Tele-end (200mm), the image may become slightly front-focused.
Download firmware 1.0.6 for the Canon RF 70-200mm f/2.8L IS USM
YuengLinger
Dec 20, 2012
2,828
1,055
Southeastern USA
Remember there’s a 1.0.5 lens firmware to install first.
Sorry, but I've read and reread instructions, I don't see that is a requirement. Here's from Canon Europe:
Quote from link: "This firmware update is for lenses equipped with firmware versions 1.0.5 or earlier. If the lens's firmware is already version 1.0.6, it is not necessary to update the firmware." (Emphasis added.)
Viggo
Dec 13, 2010
4,423
1,065
See Canon, this is how you should’ve handled my dreaded 1d3 when the first reports were in :ROFLMAO: :p
I commend Canon for this fix, it was acknowledged very fast, so they pay attention to forums, ha! To punch out the firmware this fast is excellent service. Bravo!
Reactions: YuengLinger
YuengLinger
Dec 20, 2012
2,828
1,055
Southeastern USA
How great it would be to see some before and after shots, or see lensrentals.com assess the fix!
And I suppose the world will never know if anything has been tweaked physically for the next production run...???
Joules
Jul 16, 2017
619
576
Hamburg, Germany
With how much software is already working in the RF lenses (Focus by wire, control ring, cropping the sensor to match the image circle, and so on) I believe they would prefer to solve it on that layer rather than touch the production process.
Viggo
Dec 13, 2010
4,423
1,065
Does the 70-200 really have 2,6 stops of vignetting at 200mm.? I’m baffled...
YuengLinger
Dec 20, 2012
2,828
1,055
Southeastern USA
I still believe Canon was a little aggressive with the MFD claim. Really pushed it to show it is different from the EF version. For marketing. But apparently they are making it work as claimed.
